No spark 283 - NCRS Discussion Boards
No spark 283
  • Dana B.
    • November 1, 1998
    • 147
    No spark 283
    Crusin' down the road and the '57 start cuttin out. Back in the garage found the dist cap is cracked . Replaced the cap ,rotor, points and cond. now No spark! Replace the coil. no spark. Replace ballaster. No spark. Replace ignition switch ,still now spark . Any ideas ?
  • Douglas L.
    • August 31, 2003
    • 302
    Re: No spark 283
    Dana,
    Check the ground wire that goes from the points mounting plate to the distributor housing.
    • Edward D.
      • October 25, 2014
      • 206
      Re: No spark 283
      You getting 12 volts from brown wire (ignition) to ballast resistor with key on? Check continuity of ground wire from dist to coil to ground with points closed (do this with key off). I'm assuming you set point gap to .017 when you replaced them as well.
        • 43297
        Re: No spark 283
        Dana------
        You experienced a intermittent problem when you last drove the car. Subsequently, you found a cracked distributor cap which could well have been the source of the problem. After you replaced the cap and other related parts, you found you had no spark, at all. Clearly, something was done wrong when you replaced the parts or one of the parts is defective.
        • Dana B.
          • November 1, 1998
          • 147
          Re: No spark 283
          Thanks for the ideas , I'll check these out and report back.
          • E B.
            • March 1, 1978
            • 127
            Re: No spark 283
            Clean the new point contacts with lacquer thinner. Ed
            • Wayne P.
              • August 31, 1975
              • 1025
              Re: No spark 283
              Make sure the points are closing!
              • Terry D.
                • May 31, 1987
                • 2698
                Re: No spark 283
                A bad condenser can cause no spark, start putting back on old parts except for cap till you find the problem. You are making this way harder and more expensive then it should be!
                • Terry D.
                  • May 31, 1987
                  • 2698
                  Re: No spark 283
                  So what did you find was the problem?
                  • Dana B.
                    • November 1, 1998
                    • 147
                    Re: No spark 283
                    New problem... I haven't been to the garage yet. June 6 went in for major dental surgery , and still on the mend . If all goes well, I'll be back in the garage in a couple of weeks. Thanks
                    • Dana B.
                      • November 1, 1998
                      • 147
                      Re: No spark 283
                      I recovered from the dental surgery. back in the garage today. Thanks for the all the advice. I installed the old points and condenser . Yes ,
                      I now
                      have spark !
                      • Mark E.
                        • April 1, 1993
                        • 4614
                        Re: No spark 283
                        A reminder about problem solving to first ask: what changed?
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
