65 under hood "J" clips - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1604
    for the under hood "J" clips that hold the hood release cable and wire harness on the hood gutter are they glued on or riveted on?
  • Bob R.
    • June 30, 2002
    • 1596
    Re: 65 under hood "J" clips
    I think they are held on with small fillips screws in my memory is correct.
    • Gary J.
      • April 1, 1980
      • 1246
      No riveted!
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11366
        1965 AIM UPC 11-15 Sheets B5 & B6 has some information which may help.....
        Sheet B5 shows rivet 455624, but Sym 3 in the Revision history states "Rivet added 3 places" ... 9-23-64.
        Sheet B6 shows "Bond B" at the 3 clips, but also pictures the rivets at those 3 locations. Also a Sym 2 about rivet added 9-23-64. However, Sym 2 isn't shown on the page, at least I can't find it.
        Since 1965 production started in August of 1964, early cars likely just had the 3 clips bonded, and after some AIM revision to production floor lag time, the clips were then riveted.
        If riveted, I think it would have to be done before the top surround was bonded to the firewall. I'm not sure if the rivets could be installed on a assembled/bonded body. My research shows the 455624 rivet as a soft aluminum rivet, reference post with a rivet photo Here.
        Pictures of early/late cars and their clip attachment method would obviously help.
        edit....added AIM page scans.
        • Bill M.
          • April 1, 1977
          • 1386
          My '65 was assembled in December '64. The 3 clips holding the hood release cable are riveted.
          • Mark M.
            • October 21, 2008
            • 343
            The October 64 built 65 I'm doing now has screws holding the clips. It is an AO Smith body. There may be a difference with St. Louis cars.
            • Murray S.
              • May 31, 1990
              • 75
              Mark: are you sure that your 65 is an October 64 build?
              GM had a nation wide strike in October 64;
              Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.
              https://www.nytimes.com/1964/10/26/a...n-resumes.html
              Murray
              • Tom D.
                • September 30, 1981
                • 2151
                I will be looking at an A O Smith body from March, 1965... Tomorrow.
                https://MichiganNCRS.org
                Michigan Chapter
                Tom Dingman
                • Mark M.
                  • October 21, 2008
                  • 343
                  I just checked the trim tag and it is B29 which is September 64. The cars birthday build off assembly line was mid November. Many of the parts on this car have September and I believe some October dates.Murray you are correct as the strike was somewhere around September 25 1964 to November 6 1964. Now that this question is opened as to how these j clips in 65 were fastened, I'll check a few other cars. It may help if anyone listing how the clips are held to also mention if the body is St. Louis or AO Smith.
                  • John L.
                    • February 20, 2009
                    • 186
                    • Mark M.
                      • October 21, 2008
                      • 343
                      Keith I just noticed the second half of your question which was about the hood gutter clips. I need to put my cheaters on sooner. The 64 St. Louis and 65 AO Smith I believe are put on with adhesive. The 67 St. Louis used rivets
                      • Tom D.
                        • 2151
                        These photos are from an early March A O Smith coupe. 1965 #11843 has a "H1" body date. There are four clips, and each is attached with the same type of phillips head screw - looks like an integrated washer. What do you call a round head with a flat washer included ?
                        Michigan Chapter
                        Tom Dingman
                        • Keith W.
                          • June 30, 1998
                          • 375
                          St Louis
                          Vin # 114661
                          Built Apr 7-8th Job # 356
                          • Mark M.
                            • October 21, 2008
                            • 343
                            I believe we may have to clarify the original question. Keith Brodbeck asked about the j clips on the firewall area and the side gutter clips. Attachments would vary for the two areas for a given car depending on year and body plant. The examples compiling are helping to cover the C2 variances. Any 66 or 63 owners have some input?
