70 Hole in fender rail - NCRS Discussion Boards
  • Tom F.
    Infrequent User
    • June 30, 2003
    • 13
    Re: 70 Hole in fender rale
    Yes Mark,
    IIRC, this had the hard plastic reservoir down by the inner fender and firewall.
    • Dennis D.
      • March 1, 2000
      • 1071
      Re: 70 Hole in fender rail
      FWIW I'll offer a speculation... Both the driver side harness clip hole, and the passenger washer bottles long neck bracket hole, are 71 provisions.
      I can imagine a large pile of fenders stockpiled for the 71 model, all with the holes punched out.(Jig?). Possibly done before the 70 model year was completed, So some of the 71 style fenders found their way onto late production 70's.
      The holes in my theory,(pun intended), are what are the holes doing in early model 70's.
      Insert another speculation here.... Fender replaced with factory piece,(would a service piece have the holes?), or car had a replacement fender from a doner 71 fender or front clip.
      side note: Mark. whats up with the metal shroud/alum. rad?
      • Tom F.
        Infrequent User
        • June 30, 2003
        • 13
        #18
        It's a ZR1
        • Larry M.
          • December 1, 1986
          • 541
          #19
          Interesting - even though there's no ignition shielding, there's still a bracket for mounting the passenger rear lower plug shield.
          • Dennis D.
            • March 1, 2000
            • 1071
            #20
            Very cool
            • Brady C.
              • November 1, 2004
              • 113
              #21
              Vin # 14031 / has hole on left side as the others.
              Brady Como
              #42793
              • Pat M.
                • April 1, 2006
                • 1579
                #22
                My May built 70, VIN 9753, has the driver's side drip rail hole. While I know the outer portion of this fender has been replaced, I'm fairly certain the inner portion, with the drip rail, is original.
                  • 15616
                  #23
                  Dennis
                  I believe it is a later 1970 thing. To the best of my recollection my early 1970 does not have it.
                  I have to correct my statement. I have found that hole, and one in the horizontal surface with the rivet to hold the vacuum harness retainer (called a loop) also. I have both on my end of January 1970.
                  • Leonard M.
                    • September 7, 2009
                    • 236
                    #24
                    [QUOTE=Terry McManmon (3966);852208]I have to correct my statement. I have found that hole, and one in the horizontal surface with the rivet to hold the vacuum harness retainer (called a loop) also. I have both on my end of January 1970.
                    Terry, In my opinion these holes have no historical significance in C3 Corvettes, but the earlier "Speculation" that early '70 cars with the hole all had replaced fenders was interesting to me.
                    Quoted from Dennis:
                      • 15616
                      #25
                      [QUOTE=Leonard Mankowski (50815);852210]
                      Quoted from Dennis:
                      It might be interesting, but I have owned my Corvette since new and the fender/front surround has never been replaced.
                      My guess is that hole has some use in aligning the front surround in the jig when the front end was glued together.
                      • Ron G.
                        • December 1, 1984
                        • 865
                        #26
                        Dennis,
                        is it possible you can send any more clear/definitive picture in its exact position. Thank you in advance for your effort and cooperation or you can reach out to me personally at : Rgodutilt1@yahoo.com.
                        "SOLID LIFTERS MATTER"
                        • Dennis D.
                          • March 1, 2000
                          • 1071
                          #27
                          I measured to the center of the hole on the driver side, from the beginning of the drip rail as a starting point. 31 1/2". The hole is the same distance on the passenger side. Interesting. Terry's thought of an alignment reference is making more sense.
                          • James G.
                            • August 22, 2018
                            • 800
                            #28
                            This is 401761 LT1 January Build. One owner 50k miles. Original paint. - the hole is quite visible -
                            James A Groome
                            1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                            1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                            My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                            Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                            • Michael F.
                              • 745
                              #29
                              my 70 also has that hole
                              Michael
                              70 Mulsanne Blue LT-1
                              03 Electron Blue Z06
