Tri-power Air Clean Base Bolts and Bracket Gap - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    Hi,
    I've noticed that there's about a 1/4" gap between the tri-power air cleaner base brackets and end carbs. So I can see why one of the brackets is gone because it was probably torqued down too tight and simply broke off. This seems like a bad design so I suspect I'm missing something like perhaps the original bolts had an un-threaded top portion of the shank that prevented it from being screwed down too far?
    I can see that there is no spacer listed in the assembly manual. And I have two bases and they both have the gap. I'm not expecting there to be a difference in the carb's themselves.
    Jack
    Jack Ottofaro
  • Rich G.
    • August 31, 2002
    • 1403
    • Jack O.
      • July 31, 1996
      • 527
      Re: Tri-power Air Clean Base Bolts and Bracket Gap
      Haha Rich, I know that pain as well. Thanks for the response.
      Jack Ottofaro
