too much antifreeze? - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1364
    Recently changed coolant on my 67 sb. Drained block as well as radiator. Supposed to hold 16 qts but after adding 8 qts Go5 antifreeze, would only take 6 qts distilled water even after several driving then let cool cycles so wouldn't think there's still air in system. So, I have a bit more than 50% antifreeze. I know water has better heat transfer than antifreeze but car runs in normal temp range after coolant change. Any harm in having over 50% antifreeze? Leave it alone or drain a qt or so and replace with distilled water?
  • Larry M.
    • January 1, 1992
    • 2701
    Re: too much antifreeze?
    Leave it alone.
    Larry
    • Mark E.
      • April 1, 1993
      • 4600
      Agreed. Most bottles of coolant have a table showing freeze and boiling temperatures for various levels of dilution. They often show up to 70% coolant. The Specific Heat of your mixture is a bit less than pure water but shouldn't make a noticeable difference in performance.
      Keep an eye on coolant level; it may still go down after more driving.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • William F.
        • June 9, 2009
        • 1364
        Thanks Larry and Mark
