Re: 1967 Corvette L71 Running Hot
Just my opinion and a little of experience. If your motor is pure stock, didn't have a rebuild, low miles, not using a higher lift cam, no over bore and so on. The factory settings will work very well. As i said further up in this thread, I had to go to a B28 can and light springs along with the timing because my motor isn't PURE stock. So, my point is, what works best for your motor and heat range. The settings and parts you use will be different. I hope your problem is resolved. Let us know your outcome.
