Guys since both the 427 and the 454 use the same engine casting #, is there an easy way to tell visually a 454 from a 427?? I don't know how. Don
427 vs 454
Re: 427 vs 454
Don------
The only way to know, for sure, with an engine installed in the car is to try to check rear of the harmonic balancer to see if it's counterweighted. If it is, the engine is a 454.
Any block originally built as a 454 can be converted to 427 by changing the crank and pistons. Most later 427 blocks can be converted to 454 by changing crank and pistons. Some earlier 427 blocks can be converted to 454 by the aforementioned and grinding out certain areas on the lower crankcase.
454's use different harmonic balancers and flywheels than 427's.In Appreciation of John Hinckley- Top
Re: 427 vs 454
Don,
As Joe has referenced the best option is the harmonic balancer and flywheel. The 454 engines were externally balanced by counterweights on the these 2 components. The 427 engines were internally balanced. If you can see ( with a mirror ) you might be able to determine if the back side of the balancer has this weight provision or not Checking the flywheel requires a little more effort as the flywheel underpan must be removed to see the back side of the flywheel but this would give you good visual access to inspect for the weighted area.
Ray- Top
Re: 427 vs 454
Do you want to know the current displacement? Or the original application for the block?
Joe and Ray addressed the first. The only way I know to determine the latter (there may be other ways) is the engine suffix code if the block is stamped.
Of course, there's always the sticker on the air cleaner. :-)Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Re: 427 vs 454
Don------
This is what you're looking for.
Attached FilesIn Appreciation of John Hinckley- Top
Re: 427 vs 454
427 engines and 454 engines do not share the same casting number. That, in itself, should ID whether the engine was born as a 427 or a 454.1967 Coupe 427-390 w/air- Top
Re: 427 vs 454
Jeff------
The GM #3963512 block was used for both 427 and 454 applications during the 1969-70 period. Otherwise, post factory, the 427 and 454 blocks can be interchanged as I described above.In Appreciation of John Hinckley- Top
Re: 427 vs 454
As a side note, the early 512 blocks were not ground for crank counterweight clearanceDon------
454's use different harmonic balancers and flywheels than 427's.Dick Whittington- Top
Re: 427 vs 454
And just to throw a twist into this discussion, just for the heck of it. If someone has rebuilt a 427 and stroked it with a 454 crank (or aftermarket 4.25in crank)---------------AND THEN HAD IT INTERNALLY BALANCED---------------the same 427 balancer and flywheel can be used. Thus, checking the balancer/flywheel for additional weight and determining whether it is a 427 or 454 is invalid.
My philosophy is "More cubes is still not enough". Therefore, I feel a 427 or 454 deserves to become a 496. Too much power and torque is just right!- Top
Re: 427 vs 454
Don't the 454's use a deeper oil pan also?Don------
454's use different harmonic balancers and flywheels than 427's.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
