427 vs 454 - NCRS Discussion Boards
427 vs 454
  • Don M.
    • June 30, 1998
    • 155
    427 vs 454
    Guys since both the 427 and the 454 use the same engine casting #, is there an easy way to tell visually a 454 from a 427?? I don't know how. Don
    • 43279
    Re: 427 vs 454
    Don------
    The only way to know, for sure, with an engine installed in the car is to try to check rear of the harmonic balancer to see if it's counterweighted. If it is, the engine is a 454.
    Any block originally built as a 454 can be converted to 427 by changing the crank and pistons. Most later 427 blocks can be converted to 454 by changing crank and pistons. Some earlier 427 blocks can be converted to 454 by the aforementioned and grinding out certain areas on the lower crankcase.
    454's use different harmonic balancers and flywheels than 427's.
    • Ray K.
      • July 31, 1985
      • 375
      Re: 427 vs 454
      Don,
      As Joe has referenced the best option is the harmonic balancer and flywheel. The 454 engines were externally balanced by counterweights on the these 2 components. The 427 engines were internally balanced. If you can see ( with a mirror ) you might be able to determine if the back side of the balancer has this weight provision or not Checking the flywheel requires a little more effort as the flywheel underpan must be removed to see the back side of the flywheel but this would give you good visual access to inspect for the weighted area.
      Ray
      • Mark E.
        • April 1, 1993
        • 4607
        Re: 427 vs 454
        Do you want to know the current displacement? Or the original application for the block?
        Joe and Ray addressed the first. The only way I know to determine the latter (there may be other ways) is the engine suffix code if the block is stamped.
        Of course, there's always the sticker on the air cleaner. :-)
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Don M.
          • June 30, 1998
          • 155
          Re: 427 vs 454
          Thanks guys, I will check the harmonic balancer in the morning.
            • 43279
            Re: 427 vs 454
            Don------
            This is what you're looking for.
            • Don M.
              • June 30, 1998
              • 155
              Re: 427 vs 454
              Thanks Joe, you are always a big help. Don
              • Jeff B.
                • April 30, 1980
                • 169
                Re: 427 vs 454
                427 engines and 454 engines do not share the same casting number. That, in itself, should ID whether the engine was born as a 427 or a 454.
                1967 Coupe 427-390 w/air
                  • 43279
                  Re: 427 vs 454
                  Jeff------
                  The GM #3963512 block was used for both 427 and 454 applications during the 1969-70 period. Otherwise, post factory, the 427 and 454 blocks can be interchanged as I described above.
                  • Dick W.
                    • 10483
                    Re: 427 vs 454
                    Don------
                    As a side note, the early 512 blocks were not ground for crank counterweight clearance
                    Dick Whittington
                    • Jeff B.
                      • April 30, 1980
                      • 169
                      Re: 427 vs 454
                      Joe:
                      Thanks for the info. Never to old to learn.
                      • Ray K.
                        • July 31, 1985
                        • 375
                        Re: 427 vs 454
                        All,
                        The #3963512 block also shows application for 1971 production.
                        Ray
                        • Tom P.
                          • April 1, 1980
                          • 1826
                          Re: 427 vs 454
                          And just to throw a twist into this discussion, just for the heck of it. If someone has rebuilt a 427 and stroked it with a 454 crank (or aftermarket 4.25in crank)---------------AND THEN HAD IT INTERNALLY BALANCED---------------the same 427 balancer and flywheel can be used. Thus, checking the balancer/flywheel for additional weight and determining whether it is a 427 or 454 is invalid.
                          My philosophy is "More cubes is still not enough". Therefore, I feel a 427 or 454 deserves to become a 496. Too much power and torque is just right!
                          • Kenneth B.
                            • August 31, 1984
                            • 2091
                            Re: 427 vs 454
                            Don------
                            Don't the 454's use a deeper oil pan also?
                              • 43279
                              Re: 427 vs 454
                              Kenneth------
                              No, the oil pan is not deeper. However, the internal baffle on the oil pan is set a little deeper to allow clearance for the crank.
