57 Windshield T-bolt nut - NCRS Discussion Boards
  • John J.
    • May 31, 1994
    • 59
    On the 57, the AIM shows a washer, lock washer, and nut on the windshield mounting t-bolt. The Judging guide says windshield is secured with one-piece flange/nut (nickel size flange). Which is correct? And if one-piece, does anyone have a picture of one?
    John
  • Dan P.
    • December 1, 1990
    • 683
    Re: 57 Windshield T-bolt nut
    TH JM is correct. They are Yellow cadmium . 57 Passenger car used the same nut for the lower windshield moldings. There were two styles . One is a stamped steel and the other is a nut with a washer attached to it .There is a name for the nut but can not remember it .
    • David B.
      • March 1, 1980
      • 690
      The windshield nut GRP.12.110 is Fisher Body Div. part #4644959 and was in fact utilized before and after '57 on a multitude of cars. Interestingly it is described as NUT (w/rubber washer). The AIM shows part #4621332 which could be a production part #. That number does not show up beyond the AIM.
      • Rod K.
        • 445
        Dan's picture on the left looks like mine, washer is flatter, still concave but not to the degree of the one on the right.
        • John J.
          • May 31, 1994
          • 59
          Thanks for the information. Mine actually had the nut with washer on it. Just making sure I had correct ones.
          • Troy P.
            • February 1, 1989
            • 1284
            Always called them "spinner washer nuts" because the washer spins. Of course the nut spins and the washer stays in place as they get tightened.
