Firewall grommet replacement-C2 - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 218
    Just wondering the best way to repair the new firewall grommet after replacing the engine harness ,rerouting it through the grommet.
    I assume cutting the grommet makes more sense than cutting the new harness wires.
    • 6955
    Re: Firewall grommet replacement-C2
    John, I think about the only way is to take a Razor blade and make a slice.
    • Don D.
      • May 30, 2016
      • 28
      I just replaced my grommet when I replaced the harness. I sliced the grommet in the same spot that my original grommet was sliced.
      • Brian K.
        • May 31, 2004
        • 358
        Actually you don't have to cut either. Just remove the wire plastic connector's and put wires thru and re-install plastic connector's, no cuts no fuss I'm sure this is how the factory did it.
