C1 temperature control cable - NCRS Discussion Boards
  • Jerry M.
    • March 1, 1978
    • 147
    I thought I saw a post or tutorial not long ago on replacing the control cable and spring housing for the heater switch on a C1 but I can't find it on a search. Does anyone have any guidance help.
    Thanks in advance.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: C1 temperature control cable
    Jerry do you mean the heater fan switch ?
    This thread has info for the fan switch...
    https://www.forums.ncrs.org/showthre...=heater+switch
    Rich
    • Jerry M.
      • March 1, 1978
      • 147
      Thanks Rich
      My bad, I WAS referring to the fan switch/cable and that's the thread that I had recalled seeing.
      My switch tests okay on both speeds but I'd like to do a little cosmetic work on the cable, something like your after photos show. Did you just clean up the original cable (bead blast or wire brush) or did you replace the cable somehow?
      Thanks for the help.
      Jerry
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Jerry, When I had it apart to repair and clean the internal contacts, I media blasted the metal cable/housing then used Eastwood Silver Cad paint.
        This one had bad contacts on the resistor tab rivet connections, so I had to remove the rivets and replace with the screws as I didn't have rivets that long. After cleaning the connection tabs and terminals it worked fine after assembly. The good thing about the screws is it allows future repairs easily.
        You can pry the tabs from the metal cable housing as shown to remove the cable assembly. This way you can clean the internal contacts. There is a disc inside the switch so note its orientation.
        If you're not going to take it apart you can wire brush then mask before paint. Originally they were plated.
        Rich
        • Jerry M.
          • March 1, 1978
          • 147
          Rich.
          Your meticulous work and photo documentation are always extremely helpful and inspiring.
          Thanks again,
          Jerry
          • Bob W.
            • December 1, 1977
            • 803
            Richard.
            Once again great work and photos. This needs to be added to the database above in the sticky section.
            Thanks again for all your help Bob
