Mystery about replacement engine harness - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1244
    Re: Mystery about replacement engine harness
    Also I believe in post #13 the brown wire on the right hand side plugs into the fan motor switch. The pig tail connector off of that same wire plugs into the capacitor that is located at the bottom of the instrument cluster near the ignition switch if it is still present.
    • John P.
      • August 31, 2002
      • 218
      i see What would be best access approach for these plugins? pull radio etc? I have been under dash a lot-but never had to pull instrument cluster. I see it isn't a popular activity.
      • Gary J.
        • April 1, 1980
        • 1244
        #18
        • John P.
          • August 31, 2002
          • 218
          #19
          Using AIM (awaiting DR Rebuild diagram), with input from all, its appearing more clear.
          PM sent for you Robert.
          Thanks to all.
          • Greg H.
            • 105
            #20
            Hi John,
            I found this in my library of AC data. I think your Y connector is found on page 16.
            Good Luck.
            The NCRS will not let me post this document. Do a search for "Mid-Year Corvette non-cluster dash connectors Riv 5-11-16"
            Greg
            • John P.
              • August 31, 2002
              • 218
              #21
              would this be a search in the archives here?
              • Greg H.
                • 105
                #22
                I took my advice and did not find it here in the NCRS info.
                BINGO try this
                • Gary B.
                  • February 1, 1997
                  • 7053
                  #23
                  Kudos to Dave Zuberer and Tim Welsh. That document is a masterpiece.
                  Gary
                  • John P.
                    • August 31, 2002
                    • 218
                    #24
                    And thumbs up on the Doc Rebuild wiring charts, which arrived today. Excellent advice on this purchase.
