OEM Power Antenna Bench Test Question - NCRS Discussion Boards
+ More Options
Posts
  • Steve C.
    Infrequent User
    • June 30, 2006
    • 3
    I’m hoping someone here has bench tested an OEM power antenna and can confirm that I won’t damage the motor etc. if I try to bench test the function of the power antenna before I install it on my ’66. I don't want to go through the effort of installing it only to find out the unit is dead.
    I am planning on attaching a ground to the bolt on the housing (at the bottom of the spool) and applying (one at a time) 12V to each prong of the plug to see if the motor functions and the mast moves.
    Is this a safe way to check the function?
    Thanks in advance.
  • Jim D.
    • 2885
    Re: OEM Power Antenna Bench Test Question
    Your procedure will work fine. Good luck.
    • Steve C.
      Infrequent User
      • June 30, 2006
      • 3
      Thanks for the quick response.
