'67 SB front starter brace bolt #3848408 - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3629
    What size is this bolt? This is the bolt that holds the front starter brace to the block. The bolt is in the AIM but no dimensions. AMK doesn't reproduce this bolt either.
    Leif
  • David L.
    • July 31, 1980
    • 3310
    Re: '67 SB front starter brace bolt #3848408
    According to my notes the 3848408 bolt size is 5/16"-18 X 1/2". This is the same bolt that is used to attach the horns (See UPC 12, Sheet A5) in the 1966 and 1967 assembly manuals. The 3848408 horn bolts on my 1966 have the "RSC" marking on the bolt head, however, the starter bracket bolt on the 1966 w/327 is GM # 273867.
    Dave
    • Leif A.
      • August 31, 1997
      • 3629
      Thank you David. That's one of those bolts that can't be seen, so I'll just source a correct size bolt and insert. Thanks again.
      Leif
      • David L.
        • July 31, 1980
        • 3310
        Paragon Corvette sells a reproduction starter bracket bolt 5/16"-18 X 5/8" that includes a star lock washer.
        • Leif A.
          • August 31, 1997
          • 3629
          David,
          Everything else is there. I was checking solenoid wiring chasing down an intermittent starting issue when I noticed the bolt to block missing. Thanks for the reference.
          Leif
          • David L.
            • July 31, 1980
            • 3310
            Leif,
            Attached below are 2 photos of an original 273867 bolt (5/16"-18 X 1/2") with "RBW" on the head. This bolt does not require a lock washer (see photo #2). This bolt came with the 1107247 starter dated 6E20 and 1114344 solenoid from a 1966 Chevrolet w/283 engine in a salvage yard in Massachusetts back in the 1980's. The 2 original starter bolts also have the "RBW".
            Right now I do not have very good access to my 1966 Corvette to check the 3848408 bolts that attach the horns.
            Dave
            • Leif A.
              • August 31, 1997
              • 3629
              Great info and pictures David...thanks.
              Leif
              • Mike B.
                • July 31, 1994
                • 839
                I concur. Great clear closeup shots David. The dimensions and part numbers are very helpful to bolt collectors like myself.
                Thank you,
                Mike
                • Leif A.
                  • August 31, 1997
                  • 3629
                  Home Depot...$0.78.
                  Leif
