Holley R3810 part needed - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    I this this part is called the fast idle cam for my Holley R3810 from my 1967 327-350hp. It explains to me why I had cold start issues last year with the choke ON and no elevated idle. After warming up, idle was fine. I found the serrated piece that had broken off lying on the intake manifold.
    I was hoping that the Holley from a very recent post would work, but its missing. So Now the search is on. I checked the Holley web site on the 4160 R3810 and they don't list it.
    Anyone have any ideas on where to get one?
    Don
  • Jack M.
    • March 1, 1991
    • 1195
    Re: Holley R3810 part needed
    Don- Last summer, Holley referred me to Daytona Parts for obsolete carb parts... try calling: 386-427-7108
    • Peter M.
      • May 30, 2013
      • 361
      Don,
      If you don't have any luck let me know and I will look through my spare parts pile.
      Kind regards
      • Gerard F.
        • June 30, 2004
        • 3806
        Don,
        You might check out this one at Chicago Carburetor:
        They call it a cam/actuator, generic to 66-70 holleys.
        Also google Holley fast idle cam 3810, there is one on ebay
        Jerry Fuccillo
          • 43279
          Don
          Don------
          GM #3888875 if you could find one.
          • Gerard F.
            • June 30, 2004
            • 3806
            Don,
            This one on ebay has the same part number as the one in your picture 41R539 and is correct for a 3810 by my holley parts book
            Find many great new & used options and get the best deals for Holley 41R539 Green Nylon Choke Cam 1966-70 Corvette - 2 & 4 Barrels at the best online prices at eBay! Free shipping for many products!
            Jerry Fuccillo
            • Leif A.
              • August 31, 1997
              • 3653
              Don,
              If the break is clean, I would try some Gorilla Super Glue before searching out a new part. Not a lot of pressure on that part when in place. Kinda hard to figure out how it broke in the first place.
              Leif
              • Bob K.
                • September 28, 2011
                • 36
                The fast idle cam replacement is available from a number of sources. They are usually a dark green (539) on cam . The original for the 67 was a mint green color.
                  • July 31, 1985
                  • 65
                  Bob, can you or someone else on here tell me which of the 2 fast idle cams is correct for my 3810 base motor 67? One is green, with darker edges but lighter center. The other is the yellowed white color similar to the w/s washer pump plastic hose base. One came on my 3810 replacement carb and the other on a rebuilt 3810 from Chicago Corvette. I need to putt the most correct one on for flight judging.
                  Thanks.
                  John H
                  9049
                  • Bob K.
                    • 36
                    Thanks.
                    John H
                    9049
                    John, The dark green is the current replacement that came on the service carbs. The lighter colored one is used on 68 69 dual line carbs. I have some used mint green (# 539). Call me at 314 843-7545. Bob K
