Quadrajet Inlet Filter GF 470
Re: Quadrajet Inlet Filter GF 470
Starting Fluid. If the car has been parked for a few days pop the hood, remove the air cleaner top, and spray some starting fluid down the carb throat, set the choke, and it will start on the first crank. It may not stay running, but if it stalls out the fuel pump has pumped enough gas into the fuel bowls and if you pump the gas a few times it will restart. Saves wear and tear.
Attached FilesLast edited by Dick W.; January 31, 2019, 05:44 PM.Dick Whittington- Top
It is my understanding, the Q jet leaky problem was an early problem and after 70 built cabs, they fixed the problem and few had the problem.
EdEd DiNapoli
CNJ Chapter Past Chairman/Co Founder
1972 Targa Blue Coupe, Original Owner,
Duntov Award, Sam Foltz Award,
Founders Award, NCRS Gallery VIII
2011 Corvette Convertible
NCRS Presidents Award 2014- Top
