Quadrajet Inlet Filter GF 470 - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    • Dick W.
      • 10483
      Re: Quadrajet Inlet Filter GF 470
      Originally posted by Bill Strobel (37873)
      Starting Fluid. If the car has been parked for a few days pop the hood, remove the air cleaner top, and spray some starting fluid down the carb throat, set the choke, and it will start on the first crank. It may not stay running, but if it stalls out the fuel pump has pumped enough gas into the fuel bowls and if you pump the gas a few times it will restart. Saves wear and tear.
      And breaks ring lands on pistons if you are a little indiscreet when using it.
      Dick Whittington
      • Ed D.
        • December 1, 1990
        • 330
        #18
        It is my understanding, the Q jet leaky problem was an early problem and after 70 built cabs, they fixed the problem and few had the problem.
        Ed
        Ed DiNapoli
        CNJ Chapter Past Chairman/Co Founder
        1972 Targa Blue Coupe, Original Owner,
        Duntov Award, Sam Foltz Award,
        Founders Award, NCRS Gallery VIII
        2011 Corvette Convertible
        NCRS Presidents Award 2014
