C2 hardtop restoration - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 218
    I'm not sure whether any forum rules discourage a recommendation for services, but I have a hardtop which I would like restored
    for my 1965 convertible. It is not original to the car, but is the correct vintage, in general. I do not know year of manufacture of top.
    Is the only way to confirm the hardtop year of manufacture via the glass (assuming the glass is original)?
    next question is : who should I employ to complete a full restoration?
    PM is fine if need be. Thanks in advance.
  • Harry S.
    • July 31, 2002
    • 5344
    Re: C2 hardtop restoration
    John, there are two companies that I am aware of:
    1) http://www.autoentec.com/
    2) https://www.thehardtopshop.com/
    If you have the time you can do it yourself but it is a long process.
    Good Luck
    • Bob R.
      • June 30, 2002
      • 1595
      John,
      The rear window has a date drivers side lower corner. Post what you find here and I'm sure someone can tell you the date of the top.
      • John P.
        • August 31, 2002
        • 218
        Hmm I see no date. I would have to conclude that current glass is not original.
        • Donald O.
          • May 31, 1990
          • 1593
          Not necessarily so. The date code may be hidden by the weatherstrip.
          Don
          • Michael M.
            • February 7, 2011
            • 186
            John, as you mentioned, the Plexiglas date code is probably the best indicator of the year of manufacture, but there are a few other indicators to look for - like upper and lower Plexiglas reinforcements, side notches and headliners. The format of the Plexiglas date code also changed over the years. The attached is a compilation of notes I put together when looking for a hardtop. It might be of some help.
            I used Glassworks (The Hardtop Shop) in the 2016-2017 time frame. The quality of their work was excellent but the wait time was 15 months at that time.
            Good luck!
