Replacement Battery - NCRS Discussion Boards
Replacement Battery
  • Dan L.
    • May 9, 2012
    • 97
    Replacement Battery
    I ordered a period correct/date coded reproduction battery for my 66 roadster from one of the major corvette catalog outlets on October 2nd and have still not received it - every time I check the status its always going to be shipped in two weeks. According to catalog sales rep there is no other other contract manufacturer for that reproduction battery. In my three NCRS Top Flight judging events the car has always recieved the standard 7 point deduction (even with the period correct reproduction battery). My question is if I install a modern replacement batery is the judging penalty any greater than the standard 7 points? Thanks
    Dan
    54915
  • Michael J.
    • January 27, 2009
    • 7167
    Re: Replacement Battery
    If you put in a modern Delco brand replacement (size 24), it will get a standard 12 point deduction.
    • Dan L.
      • May 9, 2012
      • 97
      Thanks Michael - I found an AC Delco M24GM on Amazon is that the one you referenced? Thanks
      • Michael J.
        • January 27, 2009
        • 7167
        Yes, that one will work. Any Group 24 Delco (not 24R) with two top posts will work. There are different prices based on different internals, warranties, CCA, etc. You could also contact your local Delco dealer to see what they have in stock. Here is an example:
        • Dan L.
          • May 9, 2012
          • 97
          • Michael J.
            • January 27, 2009
            • 7167
            That is always what I have gotten too, even with the more expensive real tar tops, they just will not allow reproduction batteries.
            • Patrick C.
              • January 16, 2013
              • 327
              $84 at Menards with a 3 year warranty. Installed mine last week.
