Holley carburetor air horn/inlet diameter - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    This isn't a corvette question, but I know the experts on this forum will know the answer.
    I put a corvette L79/350HP 490 intake and List 3367 carburetor off my 66 corvette onto my 65 El Camino with a 80s vintage 350 engine. I want to dress the 350 as a 65 Chevelle/El Camino L79 so I order a reproduction Chevelle L79 air cleaner assembly, only to find it didn't fit the air horn.
    The corvette List 3367 (model 4160) carb has a air inlet diameter where the air cleaner sites of 5". I just also measure the List 3810 (model 4150) and air cleaner base on my 67 corvette and they are 5".
    The base of the reproduction Chevelle L79 air cleaner is 5 1/8". By the way, the 65 Chevelle/El Camino L79 had a List 3043 Holley which is very similar to the 65 Corvette L79 List 3818-1. I also have a List 3818-1 and it measures 5".
    So, my question, is the 5 1/8" diameter something started with later Holley's?
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Peter M.
    • May 30, 2013
    • 358
    Re: Holley carburetor air horn/inlet diameter
    Don,
    I would not call myself a expert but I have played with old Chevys for over 50 years. The repro air cleaner is the problem in my opinion.
    Kind regards.
    • Donald H.
      • November 2, 2009
      • 2580
      Originally posted by Peter Miller (58508)
      Don,
      Kind regards.
      Thanks Peter,
      I agree, but when I look at looking at some aftermarket air cleaners most seem to have the 5 1/8" opening. This leads me to believe that at some point the size change in the Holley carbs from 5 to 5 1/8"
      Don Harris
      • Larry M.
        • January 1, 1992
        • 2695
        Originally posted by Donald Harris (51003)
        Thanks Peter,
        Don:
        This may well be the answer. The Holly website shows both 5 inch and 5-1/8 inch carb neck gaskets as available. You might want to call their tech line and inquire if and when change this took place.
        Larry
