1966 427 425HP Rocker Arm Stud Nuts - NCRS Discussion Boards
  • Joe T.
    • February 24, 2018
    • 153
    Will NCRS judging points be deducted for using Polly Nuts on rocker arm studs?
  • Leif A.
    • August 31, 1997
    • 3602
    Re: 1966 427 425HP Rocker Arm Stud Nuts
    No...not a judged item.
    Leif
      • January 31, 1988
      • 43191
      Joe------
      The bigger problem is that most such nuts will cause interference with stock valve covers.
      • Joe T.
        • February 24, 2018
        • 153
        Thank you. Didn't think so.
        Joe
        • Joe T.
          • February 24, 2018
          • 153
          Thank you Joe. I hadn't thought about clearance. After making a visual inspection and considering the dripers in the valve covers, I don't think the poly nuts will clear. Going to get a new set of lock nuts.
          Joe T.
            • January 31, 1988
            • 43191
            Joe T.
            Joe-------
            Actually, the stock-type, prevailing torque lock nuts are the best bet for rocker arms. In fact, I wish they could be used on roller trunnion rocker arms.
