What was the average amount of 427 L71 JE Stamp Pads were Stamped per Day at the Tonawanda Plant and how many workers at the plant were Stamping Engine Pads throughout a shift per day.
Tonawanda 427-435 JE Stamp Pad
- Top
Re: Tonawanda 427-435 JE Stamp Pad
Not quite. The VIN was stamped on the engine and transmission on the line where they (engine and transmission) were mated. After that they were installed in the chassis.Terry- Top
John H. said this in his presentation:
Engine Dress Line
Hang engine and transmission
Stamp VIN
Install Accessories
Engine oil and transmission fluid
Send to chassis line
Here is a picture Mike Hanson had of the VIN stamp being added in St. Louis:Attached FilesBig Tanks In the High Mountains of New Mexico- Top
Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Thanks Micheal, perfect that all I wanted to figure out how the Vin.# was Stamp and engine stamp was done , So at Tonawanda plant the engine date Stamp was done without the heads on then engines were completed then ship to St Louis , Engine and Transmission were join together then dress up Vin.# stamp then to the Chassis line , thank you- Top
I guess at the Tonawanda engine plant there was alot of Stamping Pad being whacked and I,am very surprise after stamping so many engine per day my guess is about 300, so how could it be possible that the stamping numbers meaning "Engine Stamp pad" at that particular day "claim" that all stamping pad should look the same in that certain day Claiming as of a fingerprint mark, the gangland holder after taken a beating like that all day by different day and night workers wouldn't you think the gangland fonts numbers & letters would wear or chip or been replaced and the spacing of the numbers changes and the depth of the sledge hammer hit's through out the day changes the look's of each and every stamp Pad done after so many whacks that day .Last edited by Guest; December 8, 2018, 01:05 PM.- Top
