Frame stencil - NCRS Discussion Boards
Frame stencil
  • Dale C.
    • November 1, 1999
    • 844
    Frame stencil
    I was just informed at the Lone star regionals that there is a new concencus that the frame stencil was placed on the drivers side of the frame. Mine was on the passengers side and I re-stenciled it there.
    Dale
  • Leif A.
    • August 31, 1997
    • 3650
    Re: Frame stencil
    First time I've ever heard that. But, I heard a lot of things for the first time at this past Lone Star Regionals.
    Leif
    • Stephen L.
      • May 31, 1984
      • 3162
      • Jaime G.
        • April 1, 1988
        • 480
        Re: Frame stencil
        Dale
        Dale, most stencils were applied on the drivers side, however if you have evidence yours was placed on the wrong side at the factory, the point deduction (if at all) should not be a factor.
        • Dale C.
          • November 1, 1999
          • 844
          Re: Frame stencil
          You know, a picture is worth a thousand words and I have two pictures that end my questioning on where the stenciling was placed on the 68 corvette frame. The passenger side, case closed and I'm not moving mine.
          • Jaime G.
            • April 1, 1988
            • 480
            Re: Frame stencil
            I would not change it either. Unfortunately too many times History has been rewritten and has become fact. Yours was applied on the passenger side and it should remain on the passenger side even though its not TFP. Good for you!
            • Dale C.
              • November 1, 1999
              • 844
              Re: Frame stencil
              I don't really mind as the car Top Flighted anyway. I would just like to know how it really was. I have seen extremely convincing evidence of production placement on the passengers side (pictures). If these pictures are wrong how many wrongs does it take to make it right?
                • 11692
                Re: Frame stencil
                Dale
                I've not heard that one, nor do I recall ever seeing one on the driver's side. Ever.
                Edit - see below.
                • Dale C.
                  • November 1, 1999
                  • 844
                  Re: Frame stencil
                  So happy I did not change mine to drivers side, post judging. Pat also if you have inputs to JM, I brought up the vacuum plumbing for a 68 BB with A/C. Look up my posts to Gary Bosselman, he knows about it, Oct 28 (
                    • 11692
                    Re: Frame stencil
                    I just looked through the 68-69 JG, the 70-72 5th Ed and the upcoming 70-72 6th Edition. None of them say which side the stencil is on - that will be corrected.
                    Correction - the 68-69 states the RIGHT rail, as does the 70-72. I just had to read them slower.
                    • Jimmy P.
                      • June 24, 2014
                      • 1696
                      Re: Frame stencil
                      This same practice continued for 73 and 74. Frame stencil located on RIGHT SIDE rail as
                      Patrick noted above for 68-72. Only difference is the stencil color is white in 73 and changed to yellow in 74.
                      Jimmy
                      1973 Convertible
                      L48,M20,N40
                      Mille Miglia Red/Oxblood
                      • Gary B.
                        • February 1, 1997
                        • 7064
                        Re: Frame stencil
                        So, which specific years was he stencil on he driver's side? None of the C2 years, I believe.
                        Gary
                          • 11692
                          Re: Frame stencil
                          None for C2 or C3.
                          • Gary B.
                            • February 1, 1997
                            • 7064
                            Re: Frame stencil
                            None for C2 or C3.
                            Patrick,
                            So, I take it the "consensus" at the Lone star regionals that the frame stencil was placed on the drivers side of the frame is just some judges going rogue.
                            Gary
                              • 11692
                              Re: Frame stencil
                              Originally posted by Gary Beaupre (28818)
                              Patrick,
                              Gary
                              I don't know the context or who was judging, so I can't comment on what did - or did not get said or get heard. They're not always the same. That happens to me all the time - what I say and a patient hears don't always match.
                              Yet, in my judging I have not seen one or heard of one on the left (driver's) side. But, as Terry McM says, I haven't seen them all.
