Tach Pegging At 60 During Idle On 56 - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 660
    After 34 years, I finally got my 56 running. At idle the tach pegs at 6 grand. We took apart the generator and everything seemed to work fine there. The cable seems to be working on each end. It worked fine 34 years ago when I started the restoration. I am thinking that there might be a problem with the tach? May I please get some advice on this situation? Thanks! Mark
  • Brian T.
    • September 30, 1990
    • 190
    Re: Tach Pegging At 60 During Idle On 56
    Disconnect the cable. After 34 years of sitting, and 28 years or so since it was built any original grease will have the consistency of wax. Or there is grease inside the speed cup, causing it do deflect as the magnet spins. It needs to be rebuilt. If you leave it hooked up, something will break and add to the cost of the rebuild.
    • Mark S.
      • July 31, 1983
      • 660
      Thanks! I do have it disconnected.
      • Don H.
        • December 1, 1981
        • 1490
        Have you tried to spin the cable with a drill?
        • Mark S.
          • July 31, 1983
          • 660
          Yes, I did spin the cable with a drill; and it would come up from zero with that method. Thanks!
          • Mike M.
            • May 31, 1974
            • 8399
            follow Brians advice and didn't screw with the tack. something will break an it'll be costlier to restore it. mike.
            • Mark S.
              • July 31, 1983
              • 660
              Thanks Mike! I was originally going to go into it; but decided otherwise. Your advice has been taken. Mark
