Front Spindle Dust Shield - NCRS Discussion Boards
  • Joseph R.
    • August 19, 2018
    • 45
    Hello,
    I just cleaned the front spindle dust shields also called brake backing plates on my 68 and have PN 3898011LH and 3898012RH.
    From the NCRS technical manual these are not from a 68, would anyone know what year they as i can't find it on the net?
    add picture and correct PN#'s
    thanks, Joe
    • 43272
    Re: Front Spindle Dust Shield/Brake Backing Plate
    Originally posted by Joseph R Russo (65107)
    Hello,
    thanks, Joe
    Joe-----
    GM #3898011 and 3898012 are the part numbers for the front brake rotor shields used for 1968 Corvettes.
      • 43272
      Joe------
      By the way, I should have mentioned that the part number seen on the front rotor shield photo in the Judging Guide is for a 1969 Corvette. For 1969, the front shield part numbers were GM #3953423 and 3953424. These same shields were used from 1969 through 1982.
      The 1968 shields are one-year-only. They are designed to accommodate the 65-68 spindle and the 68-82 1/2" steering arm bolts. No other year model Corvette used that combination.
      • Joseph R.
        • August 19, 2018
        • 45
        Thanks Joe,
        I'm using the 68-69 4th edition technical manual which only mentions the numbers below.
        Also mentions the finish as unpolished zinc, believe the 68 should be white/silver cadmium.
        I guess a dull silver would be good enough for judging as long as they're not painted black, gold, etc?
        Joe
        Joe------
        • David K.
          • September 30, 1979
          • 241
          Joe
          The 68-69 5th edition TIMJG is in stock at the NCRS online store
          Dave
          • Joseph R.
            • August 19, 2018
            • 45
            Thanks, David,
            Joe
            Originally posted by David King (2739)
            Joe
            Dave
              • 43272
              Thanks Joe,
              Joe
              Joe------
              1968 shields were "dull" zinc. Very few "silver-colored" plating of the period was actually cadmium. In my opinion, no one can discern cadmium from zinc plating without doing chemical analysis.
              • Gary B.
                • July 31, 1979
                • 926
                Hmmm. Another thing to add to the 68-69 TIM&JG.
                Gary Bosselman
                  • 43272
                  Gary Bosselman
                  Gary------
                  I don't know how I missed this during my review of the manual. However, the manual is not incorrect as it stands. It just omits the 1968 difference.
                    • 11692
                    Gary Bosselman
                    Yup. Looks like we listed the 69 numbers and not the 68.
                    Only took 4 years to find out we omitted it.
                    • Gary B.
                      • July 31, 1979
                      • 926
                      I'll get it added if/when another revision gets done. Good information that should be in there....
                      Gb
