Radio Connection wire identification - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    I purchased a radio connector for bench testing my midyear radio. It has three wires besides the gound. Black, gray and yellow. Can anyone identify what these colored wires represent?
    Jerry
  • Mike E.
    • February 28, 1975
    • 5153
    Re: Radio Connestion wire identification
    Knowing the year would be helpful, but generally black would be ground, gray would be power for the light, and yellow power for the radio itself.
    • Edward J.
      • September 15, 2008
      • 6960
      Jerry black is ground, gray is dash lights and Yellow is ignition.
      • Gerald C.
        • June 30, 1987
        • 1314
        Thanks for the feedback. I have attached a picture of my connection. It has two black wires, a gray and a yellow. I get what the gray and yellow represent, but one of the black wires appears to be set up for the ground, can anyone comment on the second black wire? I believe this is a 1967 radio.
        • Leif A.
          • August 31, 1997
          • 3655
          Gerald,
          If you're asking about the one with the loop connector, that goes to the "Z" bar and is attached with a self tapping screw.
          Leif
          • Gerald C.
            • June 30, 1987
            • 1314
            Leif,
            Thanks for the feedback. Is the other black also a ground so that I can attach the two blacks to a grounding source for bench testing a radio?
            Jerry
