Steering linkage. - tie rod to tie rod - NCRS Discussion Boards
  • Joseph R.
    • August 19, 2018
    • 45
    Should the distance on both side tie rod/adjuster sleeve/tie rod be the same? For example if one side has length of 16 1/2 should the other be the same. Or is a difference acceptable.
    thanks Joe
    • 43258
    Re: Steering linkage. - tie rod to tie rod
    thanks Joe
    Joe------
    It should be whatever it takes to get the car with the proper alignment (toe-in). Equal on both sides is a good starting point.
    • Joseph R.
      • August 19, 2018
      • 45
      Thanks again, Joe
      Joe------
