What is this? - NCRS Discussion Boards
What is this?
  • Jeffrey S.
    • May 31, 1988
    • 1902
    What is this?
    Hello All,
    I found this laying in the body next to the driver's side louvers just in front of the vacuum tank on my '69 small block, A/C car . I was wiping down the car to put the cover on and my hand moved this piece that was laying there. Anybody have an idea what it is?
    Thanks for your help.
    Jeff
  • Jeff W.
    • December 20, 2015
    • 101
    Re: What is this?
    I cannot find anything similar anywhere close to that location on my '68. Good luck.
    • Jeffrey S.
      • May 31, 1988
      • 1902
      Re: What is this?
      Jeff,
      Thanks for the reply. I figured it out. It is called a "SHIELD" and it is riveted perpendicular to the bracket that holds the windshield washer bag on A/C cars. I have no idea what it shields but there it is.
      Jeff
      • Dale C.
        • November 1, 1999
        • 844
        Re: What is this?
        Do you know where that shield is located in the AIM?
        • Tom D.
          • September 30, 1981
          • 2151
          Re: What is this?
          Jeff'y Sounds like it is missing. Was there another shield on the vehicle? Could it be the installer simply gave up?
          https://MichiganNCRS.org
          Michigan Chapter
          Tom Dingman
          • Jeffrey S.
            • May 31, 1988
            • 1902
            Re: What is this?
            Dale,
            The item is shown in the '69 AIM in section C60, page E4, item 7.
            Jeff
            • Jeffrey S.
              • May 31, 1988
              • 1902
              Re: What is this?
              Tom,
              The drawing in the AIM shows nothing attached to the part and it is simply riveted to the fiberglass. I'm pretty sure that it was put there to "shield" the w/w bag which is black vinyl on one side and some sort of white canvass looking material on the other and is hung on a rack which allows for the bag to move around from rubbing against the edge of the fiberglass and wearing a hole in it.
              Jeff
                • 11698
                Re: What is this?
                Interesting. It would be informative to see a photo of one on a car.
                PH
                  • 43290
                  Re: What is this?
                  PH
                  Patrick-----
                  It's GM #3954252 and is clearly shown in the AIM's, even as to configuration. It was used from 1969 thru 1972 for Corvettes with C-60. However, how it serves as an effective shield for the w/w reservoir is a mystery to me. It was discontinued from SERVICE in April, 1979.
                  • Dale C.
                    • November 1, 1999
                    • 844
                    Re: What is this?
                    Thanks I was looking in the 68 AIM
                    Dale
                      • 43290
                      Re: What is this?
                      All-----
                      I wonder how many of these things that GM ever sold in SERVICE? There was likely just one manufacturing run of these for both PRODUCTION and SERVICE. If so, the SERVICE inventory apparently lasted from 1969 until 1979. I'll bet the SERVICE inventory of these in 1979 was pretty much the same as it was in 1969 and GM just decided they were not going to continue to take up warehouse space, even as little as they required, any longer.
                      • Jeffrey S.
                        • May 31, 1988
                        • 1902
                        Re: What is this?
                        Patrick,
                        I will try to take a picture of it when I glue it back on.
                        Joe,
                        I can see what the intent of this shield is. There is a sharp edge of fiberglass structure right where the bag would hit when the car is in motion.
                        Jeff
                        • Jeffrey S.
                          • May 31, 1988
                          • 1902
                          Re: What is this?
                          PH
                          This not the best picture because it is in a hard to get to location but this is the best I could do.
                          Jeff
                            • 11698
                            Re: What is this?
                            Interesting.
                            Thanks for posting it, Jeff.
