70-72 original pcv valves - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5152
    Looking for input on a736c and a746c pcv valves. If you are pretty sure that yours is the original, factory-installed pcv valve, I would appreciate your input.
    Is it lettered AC spark plug or AC rochester?
    Does it have 4 or 8 small indentations around the body of the valve at the bottom?
    Thank you in advance for looking.
  • Jim M.
    • August 31, 1986
    • 50
    Re: 70-72 original pcv valves
    Hi Mike:
    My one-owner late December built 1971 has its original PCV valve. It reads "AC Rochester type CV 736C" and has 8 dimples around the bottom. Best regards, Jim
    • Russ S.
      • April 30, 1982
      • 2163
      Both of my 73 L82s have their original 746c PCVs and say AC spark plug and have four dimples.
      • Gary B.
        • July 31, 1979
        • 926
        My 72, base motor, has a CV736C, it says AC SPARK PLUG and has four dimples
          • 43288
          Mike-----
          I believe stamped "AC Spark Plug" and 4 indentions was typical, if not exclusive to the period. I think that valves stamped "AC Rochester" with 8 indentions came along later. In fact, much later.
          Also, valves dyed or otherwise colored came along much later. The early valves were zinc plated with no coloring.
          • David L.
            • July 31, 1980
            • 3310
            Here is a photo of some on the AC-736-C PCV valves in my collection.
            Dave
            • David L.
              • July 31, 1980
              • 3310
