Starter and alternator part numbers - NCRS Discussion Boards
  • Jay M.
    • December 1, 1991
    • 39
  • Mark E.
    • April 1, 1993
    • 4614
    Re: Starter and alternator part numbers
    The book Corvette by the Numbers is a good reference. Corvette only though. It may be available from the NCRS Store.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jay M.
      • December 1, 1991
      • 39
      Thanks for the suggestion I am looking for a source with non Corvette figments.
        • 43295
        Jay------
        There are an absolute plethora of GM part numbers for alternators and starters used across all GM car and truck lines. However, there is really very little in the way of differences within a particular series (e.g. 10DN, 10SI, etc.). For example, virtually all 10DN cases, front or rear, are functionally interchangeable. Internal differences are primarily limited to stator and rotor which vary depending upon alternator output. Any 10DN or 10SI alternator can be converted to a different output by changing the stator and/or rotor. The other difference involves clocking of the case halves. There are 4 possible clock positions of the case halves depending upon a particular chassis installation. Up to 4 different alternator part numbers can be created for alternators that are functionally identical except for case clocking.
        The same sort of thing is true for starters.
        Also keep in mind that for alternator or starters that have been through commercial rebuilding operations, the part number stamped on the unit means absolutely nothing. Commercial rebuilders disassemble alternators and starters to their component parts and build up rebuilt units from bins of parts. So, part number stampings on these units are absolutely meaningless. If one were to look up the original application for a part number found on a previously commercially rebuilt alternator or starter it will almost certainly have no relevance to the application for which the unit is presently configured.
        • Daniel S.
          • January 14, 2011
          • 309
          What is the application, or part number? If we can't figure it out there is always Google
          Dan
          • Wayne L.
            • September 30, 1981
            • 233
            Another book that is pretty good is "Catalog of Chevy V-8 Engine Casting Numbers 1955-93 and Stamped Numbers". It includes starters and alternators. ISBN 1-880524-13-9. It is put out by Cars & Parts Magazine.
            • Jay M.
              • December 1, 1991
              • 39
              I have a few take off starters and alternators that I can not find the fitment.
              Delco starter 1107273
              Delco alternator 1110-148
              • Jay M.
                • December 1, 1991
                • 39
                • Tom D.
                  • 2151
                  There are also FOUR time periods covered by CHEVROLET BY THE NUMBERS. Alan Colvin's data therein include the Corvette applications AND other non-truck Chevrolet usages. You have to buy all four to cover the full range of model years Mr. Colvin researched. See Amazon.com, where I think they are go for about $28 each. (I believe all the Corvette By The Numbers information is also in the four others.)
                  ALSO AVAILABLE ON THIS SITE!
                  Last edited by Tom D.; September 25, 2018, 07:07 PM. Reason: ALSO AVAILABLE ON THIS SITE - Added.
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                    • 43295
                    Jay------
                    The GM #1107273 was originally used for 1966 Chevrolet and GMC truck with small block and manual transmission.
                    I can't find anything on the 1110148.
                    • Jay M.
                      • December 1, 1991
                      • 39
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11370
                        Could it be 1101148?
                          • 43295
                          Thanks Joe
                          I checked the alternator again and it number 110148. I added one to many “1” to the number.
                          Jay------
                          If this is a stamped number that you are getting off an alternator case, then you now have 1 TOO FEW numbers in the series. There were no 6 digit alternator part numbers like the one you mentioned.
