1962 - Fuelie serial # and VIN on engine pad - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 307
    Hi Gents, should the serial # on the fuelie unit ID tag and the VIN on the engine pad match in 1962?
    Thank you,
    Dan
  • Wayne L.
    • September 30, 1981
    • 233
    Re: 1962 - Fuelie serial # and VIN on engine pad
    No. There may be a loose correlation, that is lower FI serial #'s would be on earlier cars, etc.
    • Daniel S.
      • January 14, 2011
      • 307
      Thanks Wayne
      Could a car with a VIN of 49xx have fuelie unit serial # of 18xx?
      Dan
      • Dan A.
        • May 31, 1974
        • 1074
        Just a rough estimate I might expect to see something in the area of unit #1646 on VIN #4900.
        • Loren L.
          • April 30, 1976
          • 4104
          Originally posted by Daniel Schutzbank (52694)
          Thanks Wayne
          Dan
          What model # FI unit?
          • Patrick S.
            • January 1, 1988
            • 209
            A little info may help. If the site would let me add a graph of vin vs serial no. you could see the relationship. I have posted it before so try looking. Oh here it is!
            Pat
            • John D.
              • December 1, 1979
              • 5507
              Patrick, Just printed your chart. Saw it before I think.
              Daniel, If your ID tag is original I would not touch it. The numbers are close enough. John
              P.S. If any of you see a 1962 fuel injection with a tag reading 7017370 instead of 7017360 don't panic. Same unit. The 7370 units were sold over the counter in the old days as a service replacement for all C1's.
