67 427 Fan Shroud - NCRS Discussion Boards
67 427 Fan Shroud
  • Jeff B.
    • April 30, 1980
    • 169
    67 427 Fan Shroud
    For 1967 w/427 engine, is the fan shroud different for an A/C car to a non-A/C car?
    1967 Coupe 427-390 w/air
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 67 427 Fan Shroud
    Jeff,
    The fan shroud was the same for both the non A/C car and the A/C car. The A/C car had a lower extension added. See attached.
    Leif
    • Jeff B.
      • April 30, 1980
      • 169
      Thanks Leif:
      I've noticed on my car the shroud seems to be in two pieces, an upper "half" and lower half, riveted together on each side. Is it possible to get a one piece shroud, or does one get the two halves and rivet them together? If only the upper half is needed, can that piece be sourced and then riveted to an original lower half? Are you saying that a non-A/C car simply did not even have this lower "half"?
      • Domenic T.
        • January 29, 2010
        • 2452
        Jeff,
        I think what Leif is saying is that they both had the upper and lower. The difference is that the AC shroud has an additional 3rd piece on the lower part.
        I bought that piece when I added factory air on my 427.
        Dom
        • Keith B.
          • September 15, 2014
          • 1604
          yes there is third piece that is bolted to the lower half. and the lower part has the square "J" clips
          • Leif A.
            • August 31, 1997
            • 3654
            Originally posted by Domenic Tallarita (51287)
            Jeff,
            Dom
            Exactly...thanks for clarifying my earlier statement Dom.
            Leif
            • Jeff B.
              • April 30, 1980
              • 169
              Thanks to all for their input.
