64 fuel tank question - NCRS Discussion Boards
    • 6942
    Guys I am looking for some advice for cleaning the inside of a fuel tank that was sitting for many years, the outside of tank is in very nice shape, inside looks like dryed up fuel??
  • Joe R.
    • July 31, 1976
    • 4550
    Re: 64 fuel tank question
    The best advice in my opinion would be to throw it away and purchase a new one!
    And you know how opinions are don't you? You will be hearing from them!
    JR
    PS. You already heard from one!
    • Mike M.
      • May 31, 1974
      • 8382
      i agree with JR. mike
      • Michael J.
        • January 27, 2009
        • 7122
        I would third that opinion.
          • 15669
          Well, if you want to give it a try pouring some acetone into the tank, but if you find any corrosion on the inside I agree with the previous opinions.
            • 6942
            Guys yes I agree any rust and I will toss it. Duke I will try some acetone. just to see what happens.
            • Keith B.
              • September 15, 2014
              • 1582
              a new tank is around 200 bucks. how much is your time worth trying things that might not work and if its not clean can cause headaches later down the road. just replace it. it will be cheaper in the long run
                • 6942
                Keith I was thinking the original style tanks maybe somehow the originals were some how different in the total gallons, the originals were 18 gallons, I done think the repro tanks are 18 gallons. also I thinking that maybe the originals may have different baffling ? but I am going to study if they are different.
                • Joe R.
                  • July 31, 1976
                  • 4550
                  Edward,
                  The replacement tanks are exactly like the originals made by the same company with the original logo stamped into the tank. Give it up and get you a NEW tank.
                  JR
                  • Mike M.
                    • May 31, 1974
                    • 8382
                    as usual, I agree with JR in that the current repo tanks can't be differentiated from originals. I might add that GM over the counter tanks from the 70's and 80's were different from original c-2 tanks. mike
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      If your going to do it any way because we all know that these cars take a bit of work to keep the cost down, I might suggest carb cleaner if you have it. I only find that Berrymans works on that stuff.
                      The acetone may do the trick, but I have carb cleaner in 5 gal buckets and a gallon would do it and then could be re used on other parts when done. I used it in motorcycle tanks to clean them and it worked like a champ. In your situation you will have the tank O-ring swell with carb cleaner. Don't think the acetone would hurt it.
                      Dom
                      • Alan D.
                        • January 1, 2005
                        • 2038
                        Just to answer the baffling question, the original's did not have as I recall.
                          • 43219
                          Alan------
                          Yup. No baffling in the originals and no baffling in the reproductions.
                            • 43219
                            Mike-----
                            Correct. Beginning about late 1969 GM discontinued the C2 tanks and replaced them with the C3 tanks. These are slightly differently configured and all have an integral pressure/vacuum valve. No original 1963-L69 Corvette was originally equipped with a tank with an integral pressure vacuum valve. Functionally, it's not a bad idea to have one since it allows the use of a sealed type fuel cap.
                            • Gerald C.
                              • June 30, 1987
                              • 1283
                              Okay, the gas tank I have has solid gasoline from sitting. I read that baking soda, vinegar and water will dissolve this mess. OR should I just toss it and buy a new one?
