Starting box with TI - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    I have a box I made to start the engine in the frame before the body drop that works very good with standard ignition. My question is will it work with a 350 LT-1 with transistor ignition or will I need to add something to make it work.
    Lyle
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Starting box with TI
    45 hits and no reply?
    Lyle
    • Gary B.
      • July 31, 1979
      • 926
      Lyle,
      You will need a TI box, hooked up properly, gounded, thru the ignition switch. Or, put in a points style distributor.
      I have a front half of a frame I use, with a radiator, on wheels. I have a TI box wired in, and just wire it differently for a points distributor.
      Gary B
      • Jim D.
        • 2884
        Okay. I have no idea what kind of a "magic box" you have but, no parts of a regular ignition system are interchangeable with T.I. ignition. I recently fired up my 65 BB (with T.I) on the chassis and simply used a spare point type distributor and coil because I didn't want to go through the hassle of all the extra wiring and mounting of the T.I. amplifier.
        • Harmon C.
          • August 31, 1994
          • 3228
          Thanks I will use a points type distributor for the test.
          Lyle
          • Mark G.
            • January 31, 2007
            • 177
            I think you can use a 4 terminal Delco D1906 HEI module and the t.i. distributor to trigger it. Any point coil will work.
