Best way to insert the spring into the gas filler drain tube on a '69? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    What's the best way to get the spring into the rubber gas filler drain tube on a 69 coupe?
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Best way to insert the spring into the gas filler drain tube on a '69?
    As you slide it in turn it in the opposite direction as wound. That will cause the spring to coil down making it a smaller diameter. Soap or dish detergent will make it slide easier.
    • Jeffrey S.
      • May 31, 1988
      • 1900
      Here's a link to Doc Rebuild tips:
      Web catalog of 700+ pages, 1000+ illustrations, 12,000+ Corvette restoration parts available mail order. Dr Rebuild Corvette Products manufacturing & distributing parts for 1953-1982 models for 22 years.
      Hope this helps.
      Jeff
      • Michael J.
        • January 27, 2009
        • 7167
        Interesting the old Doc, though he has no respect for NCRS or originality, mentions how originals were done. Maybe he is mellowing.........
        • Michael L.
          • December 15, 2006
          • 1416
          OK so I used Doc rebuilds idea and inserted the spring with the rod. It made it MUCH easier, but the spring is now "impacted" in the first ten inches of the hose. Is this how the originals were? I'm guessing, since this thing is the fuel overflow hose, that it was critically important that it drain to the ground and not get tucked up inside the body somewhere where it could let fuel collect. If that's the case then maybe the purpose of the spring is at least partly to weigh the end of the hose down and keep it directed towards the ground?
          Mike
          • Don H.
            Moderator
            • June 16, 2009
            • 2282
            Mike
            the end of the spring should be at the very end of the hose, nearest the ground.
            Spray silicone lube up inside the hose to allow you to pull the spring to the very end of the hose.
            • Michael L.
              • December 15, 2006
              • 1416
              • Michael J.
                • January 27, 2009
                • 7167
                Many of us who do this for judging, are not concerned about the spring going the entire length of the hose...........if you know what I mean......
                • Jeff W.
                  • December 20, 2015
                  • 101
                  And there should be a strap holding the drain tube in place inside the bumperett so movement of the tube should be quite hard.
                  • Mark G.
                    • January 31, 2007
                    • 177
                    Thanks for the tip on how to install the spring. What's involved in installing the hose onto the nipple?
                    • Gary S.
                      • July 31, 1992
                      • 1633
                      If you are talking about the gas drain "cup" then insert the tube in very warm water for a minute or so.
                      • Mark G.
                        • January 31, 2007
                        • 177
                        That's it, but how do I access the nipple, assuming it is there?
                        • Jeff W.
                          • December 20, 2015
                          • 101
                          You can access the nipple by pulling back the filler inlet seal. It is visible between the inlet and the body.
                          • Mark G.
                            • January 31, 2007
                            • 177
                            I have the filler door and bezel off and the rubber cup removed from under the body panel. Do I just stretch over and off of the fuel cap bung on the tank?
                            edit: I got it and of course there isn't a nipple. Hate to pay $13 s&h for a $3.00 part. Will any ole plastic nipple work or it it something special?
                            • Jeff W.
                              • December 20, 2015
                              • 101
                              Other than originality, no, I don't think there is anything special about the nipple. This is mine. I presume it is OEM. The nipple feeds through the washer and then through the rubber cup to the hose. The washer butts up against the collar of the rubber cup.
                              This is the AIM illustration for 1968
