Do you need to pull the distributor to replace the vacuum can? The plate that the points sit on blocks removing the screw holding the vacuum can in place.
Changing vacuum advance canister
Re: Changing vacuum advance canister
John, I have done it before without removing the Dist. if you have a vacuum pump and the old can works, draw a vacuum this will move the plate some.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
try using a flat blade screw driver and use one of the vac. can screws to rotate the plate. the spring in the can sometime be strong.i believe that you can find a couple of places to use to rotate. other wise remove the dist. as this is really the correct way.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
