Changing vacuum advance canister - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2421
    Do you need to pull the distributor to replace the vacuum can? The plate that the points sit on blocks removing the screw holding the vacuum can in place.
    • 6957
    Re: Changing vacuum advance canister
    John, I have done it before without removing the Dist. if you have a vacuum pump and the old can works, draw a vacuum this will move the plate some.
    • John F.
      • March 23, 2008
      • 2421
      Both hold down screws are blocked and I don't have a pump.
        • 6957
        try using a flat blade screw driver and use one of the vac. can screws to rotate the plate. the spring in the can sometime be strong.i believe that you can find a couple of places to use to rotate. other wise remove the dist. as this is really the correct way.
        • John L.
          • February 20, 2009
          • 186
          Yes it can be done - one additional comment - use a magnetic screw driver - you can manually rotate the lever/plate but much easier with vacuum source of some kind.
          • Jim D.
            • 2885
            Why not simply remove the distributor? It's easier than bending over the fender and you can then shim the end play if it hasn't already been done.
            • John F.
              • March 23, 2008
              • 2421
              Thank you Ed. I got it in and only dropped one screw close by.
