Bogus 70 ZR1 on eBay. - NCRS Discussion Boards
  • Mathew S.
    • July 9, 2015
    • 137
  • Steve B.
    • March 1, 2002
    • 1190
    Re: Bogus 70 ZR1 on eBay.
    Lots of bogus and misrepresented cars on ebay, thanks for heads up. I don't think that car is fooling anyone with knowledge.
    • Mark E.
      • April 1, 1993
      • 4597
      Hopefully an informed buyer would expect much more documentation for a car claiming to be a ZR-1.
      Shiny paint though.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
        • 43246
        Originally posted by Mathew Stark (61369)
        https://www.ebay.com/itm/1970-Chevro...9bBIGy&vxp=mtr
        I have known this car for over 30 years. It started life as a 350 horse car. The owner at that time competed in NCCC speed events, and at the time to run LT-1 specs or reduce weight you had to be all or none. So the owner took measurements and photos of our LT-1, ordered a bunch of parts from GM and went to swap meets in around 1985. The car was built to the limits allowed by the rulebook at that time. This owner later stopped autocross competition and went drag racing only. The car was sold to another gentleman who started to autocross it again like you see in the photos for the most part. There was a roll bar, the reason for the cut outs in the rear deck, and want to say a bar forward through the front floor board.
        In the late 90s or early 2000s the engine blew up, and was towed home in an enclosed trailer by a friend. During that trip the suburban crossed the median due to load shifting (theory from the friend). The trailer was struck in the front corner by a minivan busting the nose fiberglass. The nose is a replacement.
        Based on this info that dealer is full of it. It has sold on eBay no less than 3 times, yet hadn’t changed hands. When it was first listed I did provide details to the dealer, which I suspect the previous owner disclosed. The car was never represented as a real LT-1 to the previous owner. The engine lock with stamping is horrible Restamp. The tach is clearly not correct, among other issues. I will say it was a fun, fast car and for a driver what could be a decent price.
        Mathew------
        The engine block VIN derivative and engine code are about the worst I've ever seen. Wrong everything. It's hard to imagine how someone could get it this wrong and even hope that it would be accepted as original.
        • Dick W.
          • 10483
          Mathew------
          I must be looking in the wrong place, I see no block stamps
          Dick Whittington
          • Donald O.
            • May 31, 1990
            • 1591
            Mathew------
            I agree. It looks like Stevie Wonder did the stamping.
            • Mathew S.
              • July 9, 2015
              • 137
              Have to click “see full item description”. The claims and stamping are a must be seen to fully appreciate.
              • Patrick B.
                • August 31, 1985
                • 2002
                  • 11659
                  Here:
                  • Dick W.
                    • 10483
                    Here:
                    Thanks Doc Pat. About as bad as you see. You would not need to ask the "Master"
                    who posted below
                    Dick Whittington
                    • Mark E.
                      • April 1, 1993
                      • 4597
                      Originally posted by Patrick Boyd (9110)
                      The “M22” photo also shows an M20 wide ratio with an apparently correct vin stamp.
                      How can you tell it's an M20?
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                        • 43246
                        Dick------
                        You have to scroll way over to near the end of the photos.
                        • Patrick B.
                          • August 31, 1985
                          • 2002
                          In 1970 and maybe 1969 the letter after the Muncie date identifies the trans, A for M20, B for M21 and C for M22.
                            • 15610
                            Mark,
                            We put the information Pat mentioned in the TIM&JG so everyone would know. Transparency!
                            • Michael J.
                              • January 27, 2009
                              • 7141
                              Seems the current bid reflects the fair value.......... And no one is fooled yet.
