C-3 1970 Oil Filler Cap Embossed Discription - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: C-3 1970 Oil Filler Cap Embossed Discription
    Originally posted by Gary Bosselman (2575)
    Jimmy, Did the 73-74 use the FC-77 caps? I am still petty sure the FC2 is a 69 and 70 oil cap. Need to look more though...
    Gary B
    Gary,
    We haven't found one on a 73 or 74 yet. The most common one so far has been the FC2.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • David L.
      • July 31, 1980
      • 3310
      Originally posted by Justin Sibbring (58615)
      Dave,
      I didn't know that the '70 L34 had painted valve covers. Was this a change during the strike?
      Justin,
      The red AC FC-2 oil cap came from a 70 Camaro SS 350 (300 HP, L48 engine made in Tonowanda with painted valve covers). The 70 Camaro Z28 oil caps were chrome and made by Stant with the letter "S" stamped on the rivet head and the engines were made in Flint with cast aluminum covers.
      Dave
        • 43219
        #18
        Dave,
        Justin----
        L-34 was a 350/360 HP 396 used in 1966-69 Chevelles. It was never a Corvette engine. All L-34 had chrome valve covers.
          • 43219
          #19
          Thank you. Notice the difference of the center rivet? The NOS rivet is almost a perfect circle and the other is not.
          Great pictures, thanks!!!
          Gary B
          Gary------
          I expect that the AC Division was making these things by the millions during the period. The differences probably relate to different sets of tooling or wear on tooling. This is just the kind of difference that tooling wear causes. For example, the cap on the left was probably made from tooling early in its wear cycle. The cap on the right probably made from tooling late in its wear cycle.
          • Tom R.
            • June 30, 1993
            • 4099
            #20
            The material of each looks different, chrome/stainless vs. steel?
            Tom Russo
            78 SA NCRS 5 Star Bowtie
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Clark E.
              • March 1, 1991
              • 163
              #21
              Thanks Guys...The AC-FC-77 cap I have looks exactly like the unpainted cap posted by David except the word "FILL" is directly under the top "knob" rather than the word "OIL" as shown in the pic. The font is identical.
              Is it correct to assume the Tonawanda Plant produced the base 350/300 engine for all 1970 GM models and that production runs were sent to multiple assembly locations?
              Gary's offer to review of his cap inventory may result in additional information...Clark
                • 43219
                #22
                Clark-----
                No, Tonawanda did not produce small block engines for Corvettes.
                • Clark E.
                  • March 1, 1991
                  • 163
                  #23
                  OK Guys...Since the original post on July 10, has anyone had a chance to check their "oil cap archives" to help pinpoint the FC-77 application? Thanks...Clark
                  • David L.
                    • July 31, 1980
                    • 3310
                    #24
                    Clark,
                    Since I have about 60 or more vintage Chevrolet parts catalogs and Chevrolet & GM Parts History manual I did a bit of research.
                    Gr. 1.758 Oil Caps
                    3835665 (FC-2) replaced by 850843 sometime between April 1975 and September 1975.
                    The 850843 first used on 1976 Chevrolets w/V8 (exc. 454)
                    However, my 1971 Pontiac Parts Catalog (Sept. 1970) lists the 850843 cap as "FC-2".
                    Therefore, both the 3835665 and the 850853 caps were stamped FC-2 in and around Sept. 1970.
                    850843 (FC-2) replaced by 6410893 (FC77) sometime between Jan. 1982 and Jan. 1990.
                    6410893 (FC77) replaced by 6410961 (FC91) sometime between Jan. 1982 and Jan. 1990.
                    6410961 (FC91) replaced by 12334506 (FC-125) sometime between Jan. 1982 and Jan. 1990.
                    6410961 is listed in my 1976-1981 Chevrolet Parts Catalog (Dec. 1983) for 76-81 ALL (1.4, 1.6, 140, 262, 305, 350, 400).
                    850843 is listed in my 1976-1981 Chevrolet Parts Catalog ( Sept. 1980) for 76-81 ALL.
                    Maybe this will shed a little light on the FC-77 oil cap.
                    Dave
                    • Clark E.
                      • March 1, 1991
                      • 163
                      #25
                      Thanks Dave...Appreciate your research. You indicate above both the FC-2 caps were stamped in and around Sept, 1970. Do your records reflect what cap (s) were used on the 350/300 prior to that date? A takeaway is the FC-77 although identical to the FC-2 wasn't introduced until after Jan. 1982. Correct? Clark
                        • 43219
                        #26
                        Clark-----
                        The FC-2 was used for 1969 300/350.
                        It was also used for the 300/350 application through 1970
                        • David L.
                          • July 31, 1980
                          • 3310
                          #27
                          Clark,
                          GM # 3835665 is listed in my 1970 Chevrolet parts catalogs (effective Apr. 1970 and effective Oct. 1970).
                          What do you mean by a "takeaway"?
                          GM # 6410893 appears in my 1982 Corvette Parts Catalog (effective November 1981) for the 81 Corvette.
                          GM # 850843 appears in my 1982 Corvette Parts Catalog (effective November 1981) for the 69-80 Corvettes.
                          GM # 14047082 appears in my 1982 Corvette Parts Catalog (effective November 1981) for the 82 Corvette.
                          Dave
