Heat riser valve clocking - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2417
    I believe my heat riser valve is clocked wrong. See two pictures attached. From underneath, I think I need to rotate CCW. Correct!
  • John F.
    • March 23, 2008
    • 2417
    Re: Heat riser valve clocking
    I got two nuts off and one stud all the way out. Now the header pipe doesn't want to come all the way past the studs. Surely , I don't need to disassemble one side of the exhaust system to get it to drop, do I? Or take off the right side manifold? Any easy ways?
    I loosened the the clamp next to the cross-brace and gained a little wiggle room and pried down a bit. It is now off and soaking in Evaporust (my favorite rust remover). The riser was a little frozen up due to being installed wrong and not allowing it to work as it should.
    • Wayne L.
      • September 30, 1981
      • 233
      I removed the right side exhaust manifold when I had the same issue.
      • Paul D.
        • September 30, 1996
        • 491
        Exhaust pipe looks relatively new and rust free. Would removing RH pipe and muffler not be easier than manifold?
        • Bob R.
          • June 30, 2002
          • 1595
          It's been a while since I last worked on that but I believe removing the bolts from the forward exhaust pipe and just pull it down below the manifold bolts. The exhaust system had enough movement in it to allow the removal and replacement of the heat riser. I might have loosened the center exhaust hanger a little also. I definitely didn't remove anything completely.
            • 6950
            John, See if you can remove the studs on manifold first. then the heat riser can be rotated. take a couple of 3/8 nuts and lock them together and use the top nut with a open end wrench.
            • Gene M.
              • April 1, 1985
              • 4232
              Correct flange, nuts and correct length studs would help your situation.
              • John F.
                • March 23, 2008
                • 2417
                Thank you all for the advice. I got the frozen up heat riser off by loosening the clamp near the cross brace and a little prying and soaked it all day in Evaporust. See pics of results. I have new gaskets to pick up at O'Reilly's tomorrow.
                • Brad Hillhouse (37766)
                  John, it is fun and interesting to put a bolt in a vice and put that heat riser on the bolt and then hit it with a heat gun on high heat and then just no heat with fan to watch it operate and see how it reacts to cool, warm, hot exhaust hitting it in operation on the car.
                  Brad Hillhouse
                  #37766
                  • Paul D.
                    • 491
                    Back in the late 70's and early 80's I worked in a Chevy dealership and GM offered "Heat riser valve lubricant" in a spray can. Every tech had a can on his bench, but used it primarily as a rust penetrant. It worked great! Chip.
                      • 11678
                      It's now GM 88862628 Rust Penetrant and Inhibitor
                      • John F.
                        • March 23, 2008
                        • 2417
                        I ended up tying the valve open.
                          • 43259
                          John------
                          That's the best approach. For non-judged cars, removing the valve and installing a spacer (as used for FI applications) works well.
