72 LT-1 engine rebuild encountered a few questions - NCRS Discussion Boards
  • Robert D.
    • April 17, 2017
    • 18
    I am rebuilding my feb 72 built car CKY designated engine and have a few questions. First I have re-installed the correct water pump and harmonic balancer and my pulleys don't look like they will work.
    i have 3858533 BJ pulley on the balancer I think this is correct?
    and I have 3991423 BW for the water pump...I don't think this is correct?
    what are the correct ones and are there other applications that they were used on to aid my search?
    also, I have two windage trays. The one that was on the motor I have re-installed is the shorter style in the photo and I also have another one that has two more bolt holes and extends over an additional main cap. Can anyone shed some light on the differences and correct application for my car?
    thank you for any assistance
    Robert
  • Robert D.
    • April 17, 2017
    • 18
    Re: 72 LT-1 engine rebuild encountered a few questions
    Here is what the pump and balancer look like... the valve covers, carb and intake are just there for paint and not being used
    • Larry M.
      • December 1, 1986
      • 541
      • Robert D.
        • April 17, 2017
        • 18
        Thank you,
        robert
        • Larry M.
          • December 1, 1986
          • 541
          Robert,
          The water pump pulley on ours is 3991423 BW. Sorry, but I'm not able to view the number on the lower pulley.
          You may already have a copy of the Assembly Manual for your car, but in case not, the two attached scans may give you some help.
          Larry
          • Patrick B.
            • August 31, 1985
            • 2003
            That water pump looks longer than the water pump used on a 70 LT-1.
            • Mark E.
              • April 1, 1993
              • 4598
              Robert,
              Why do you primer the engine?
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Robert D.
                • April 17, 2017
                • 18
                Robert,
                I used eastwood it was a high temp etching primer? I don't want flaking after pulling the motor?
                  • 43247
                  Patrick------
                  The1970 and 71+ small block water pumps are different. The 71+ are slightly longer.
                    • 43247
                    Robert------
                    The problem is that the primer will cause the finished paint to look too "thick" and "smooth". Most engine paints are self-priming. If the engine surfaces are clean and oil-free, the paint will not chip off. If the engine surfaces are not clean and oil-free, even with the primer the paint will chip off.
                      • 43247
                      Robert
                      Robert------
                      GM #3858533 is the correct balancer pulley. I do not recall the correct water pump pulley and I can't check my references because I'm out-of-town. 3991423 might be the correct one, though. Your application also used a single groove, add-on water pump pulley which served as the AIR pump driver pulley.
                      The windage tray you have installed is correct. The longer but otherwise similarly configured tray was not used on any pre-1975 Corvette. It was used on 1975 and later with L-82.
                      • Robert D.
                        • April 17, 2017
                        • 18
                        Robert------
                        Thank you. At this point it is what it is. I've spent a fortune on Eastwood paints that really don't go very far.
                        • Robert D.
                          • April 17, 2017
                          • 18
                          Any ideas what would cause my pulleys not to line up? I just ordered the 3991425 BX add on since I know it's not with my smog system. Ill double check my notes on the water pump.
                            • 43247
                            Robert-----
                            It could be that the harmonic balancer is not on far enough (i.e. the snout is not seated on the crank sprocket) or the water pump hub is not installed at the correct spacing.
                            The 1971-82 Corvette waterpump pulleys have VERY limited other applications. They were not used on any other passenger cars. They may have been used on some MD/HD trucks.
                            • Robert D.
                              • April 17, 2017
                              • 18
                              So I called and verified (car is in Maine while apart I'm in pa and have been running back and forth for the build)
                              Water pump number is 3991399. H261 with the thicker output shaft the pump that was on before was incorrect and different height
                              balancer pulley 3858533 BJ
                              water pump 3991423 BW
                              the balancer is new and pictured here it's dimensions are correct I'm wondering if the shaft on the crank part is different?
