72 LT-1 engine rebuild encountered a few questions
Re: 72 LT-1 engine rebuild encountered a few questions
Sorry maybe bad jargon... thank you for the help
Attached Files- Top
Photos of balancer are from when I purchased it again my car is in Maine and I'm in pa. I will have my brother go and take some pictures and measurements. It is believed the balancer is "home" also I believe the shaft extends almost or approximately flush with the rear of the balancer or about 1 5/8" from face to butt end. I came back to pa Sunday after assembling the motor over the weekend. I'll update when I have more info.
If it is supposed to extend beyond the rear of the damper that may be the answer. I just looked up the specs for 3942538
And it appears it should also be 1-3/4" thick? I think this may be the problem and answer.
is it confirmed that my pullies are correct?
thank you again
Robert- Top
