#1 spark plug wire placement on 69 427/435 - NCRS Discussion Boards
    • 6948
    Can someone look or tell me is cylinder 1 wire to on dist. cap to the left or right of window? thanks Ed
  • Tom D.
    • September 30, 1981
    • 2137
    Re: #1 spark plug wire placement on 69 427/435
    Depends where you are standing... More seriously, look for a diagram, in your GM service manual or perhaps on line. Make sure you are looking at a Chevy V8 diagram.
    Looks something like this.
    these things are a deceptively simply but necessary component on your engine, they range from the cheap stamped steel, and non adjustable versions to the much nicer adjustable versions, ONE basic thing youll need to know is where TDC, 90,180,270 degrees are located if and when you get involved...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
      • 6948
      Tom, I did look on line they generally show the view of cap with no hold down screws and no vacuum advance placement. if your sitting driver seat, right or left?
      • Tom D.
        • 2137
        Michigan Chapter
        Tom Dingman
        • Ken A.
          • July 31, 1986
          • 929
          I belive this picture incorrect. It should be to the left when looking from the top.
          • Leif A.
            • August 31, 1997
            • 3642
            Originally posted by Tom Dingman (4889)
            Tom,
            Now, you've raised my curiosity. Where's your vacuum advance line? There doesn't appear to be a nipple on the end of the vacuum canister for one.
            Leif
            • Michael H.
              • December 1, 1987
              • 730
              Leif,
              It's an L88 distributor it has no nipple.
              Mike
              • Leif A.
                • August 31, 1997
                • 3642
                Originally posted by Michael Hanley (12271)
                Leif,
                Mike
                Thank you, Mike...that makes complete sense.
                Leif
                • Mark E.
                  • April 1, 1993
                  • 4597
                  Check the AIM. The few I have seen show the clocking of the distributor relative to the engine center line and placement of each cylinder's wire in the cap.
                  Contrary to Tom's photo, the VAC points 3 o'clock and #1 wire goes in the terminal over the window for most C3 big blocks (maybe L88 is different.). The perspective is looking down on the engine, with the front at 12 o'clock.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Chris H.
                    • April 1, 2000
                    • 837
                    Ed, here's a photo of my arrangement. My finger is on #1. Chris
                      • 6948
                      Guys thanks for taking the time to post and advice, Ed
