1978 Differential Codes - NCRS Discussion Boards
  • Charlie P.
    • July 31, 2003
    • 260
    The stamping on the differential doesn't get judged, but I have access to it now and am curious as to the coding. The ratio codes are in the JG- mine is "OH" for 3.55-but I don't see any other code info.
    The other characters are: 007 W8 E1. How would this decode?
    Charlie
    • 43272
    Re: 1978 Differential Codes
    Charlie
    Charlie------
    For some reason, differential unit stamped coding often varies in strange ways. I don't think that yours is typical. In any event, here's what I THINK it decodes to:
    007 is PROBABLY the julian day of the year. If so, this would make it the 7th of January
    W= Warren, MI gear and axle plant. All 1963-79 Corvette differential carrier units were manufactured at Warren
    8 PROBABLY represents the last digit of the year (i.e. 1978)
    E= Eaton posi unit. All 1966-79 Corvette differential carrier units were originally equipped with an Eaton posi unit.
    1= shift at Warren at which the unit was manufactured.
    There are often quite a few "permutations" of the stamping usually containing the same information but "arranged" in different ways. I have no idea why it was this way
