Stall - NCRS Discussion Boards
Stall
  • Bill M.
    • 1328
    Stall
    When I was driving 65 327 365 hp car up a 2 mile long hill yesterday she stalled 4 times to top of hill. Felt like I was out of fuel. After each stall she restarted after a complete stop. I am thinking that the fuel pump diaphragm is leaking . I removed fuel cap during on of the stops and it still happened. Any one come across this before?
  • David M.
    • September 30, 2004
    • 522
    Re: Stall
    When it stalls look down the carb while actuating the throttle. No gas coming out of the accelerator pump squirters, then yes fuel starvation is the likely cause.
    Next verify the fuel filter is good. Then verify the pump pressure is in spec with a fuel pump/vac gauge. If both check out it could be a leak in the fuel line or a bad pick up in the tank. If the tanks never been down for a cleaning/inspection there is likely crud in there plugging the sock on the pick up tube.
    • Bill M.
      • 1328
      Re: Stall
      Thanks Dave I will take a look his weekend. Tank and pump replaced 15 years ago.
      • George J.
        • March 1, 1999
        • 775
        Re: Stall
        I would check the fuel pump first. I seem to be going through them every few years. Either the spring for the pump arm goes, or the diaphragm goes.
        • Bill M.
          • 1328
          Re: Stall
          George just ordered a rebuild kit from LIC. I have a spare pump which I will rebuild first and then rebuild the original.
          • Bill M.
            • 1328
            Re: Stall
            thanks all for input. Changed the fuel filter and she went up that hill like a Wet Hen
            Bill
            • George J.
              • March 1, 1999
              • 775
              Re: Stall
              Bill,
              Glad to see you got it resolved.
              George
              • Mark E.
                • April 1, 1993
                • 4587
                Re: Stall
                Bill
                Is that good? The wet hen part.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Bill M.
                  • 1328
                  Re: Stall
                  yes when hens get wet they run like a properly tuned corvette. Look it up its in the farmers almanac!!
