70 Convertible Top Weatherstrip Sealant 84b - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    The AIM calls out a sealant for top frame weatherstrips they label 84b. What exactly is this sealant? I do not see a great deal of sealant on the top frame where weatherstrips attach.
    Bill
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 70 Convertible Top Weatherstrip Sealant 84b
    Bill,
    In the 1970 AIM, section 0 page D9, it indicates that 84b is sealing compound part number 3910409. It also spells out other locations where this was used. Keep up the good work!
    Mike
    • Bill L.
      • February 1, 2004
      • 1403
      Thank you Mike.
      Pretty sure it is the gray rope caulk.
      Originally posted by Mike Ernst (211)
      Bill,
      Mike
      • Dick W.
        • 10483
        Bill
        I have used contact cement made by Weldwood. They have a off yellow that is very close to what you see on the cars. Properly applied I guarantee that your weatherstrip will not come loose
        Dick Whittington
        • Ron G.
          • December 1, 1984
          • 865
          Bill,
          I am of the opinion that the same sealant was used in those odd shaped chrome pieces where the screw for the t-top adjustment plate is. If you look at original cars the black sealant actually oozes out. On the majority of all restored cars it is cut even with the configuration of the chrome
          tab.
          - Ron
          "SOLID LIFTERS MATTER"
          • Bill L.
            • February 1, 2004
            • 1403
            Thank you Ron,
            That is the way I was leaning. I finally did find a very tiny bit of the sealant on the frame.
            Kind Regards,
            Bill
            Originally posted by Ron Goduti (8076)
            Bill,
            tab.
            - Ron
              • 6948
              Bill, Home depot sells the gray rope chalk and its cheap in the Weatherstrip area of store, I that some areas also use the black 3m strip chalk.
