70 wiper arm washer tubes - NCRS Discussion Boards
  • Mathew S.
    • July 9, 2015
    • 137
    After fixing my washer pump, the tube came lose from the arm. How does one attach the plastic clips to the arm and tube? Is there a preferred method to reattach the tube to the tab on the right side (passenger side). Looks like it was soldered before, but hard to tell.
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 70 wiper arm washer tubes
    Clean it up. clamp it in place and re-solder. Propane torch will work best.
    • Harmon C.
      • August 31, 1994
      • 3228
      If you have covers over the springs your OK to install the clips. Many cars have no metal covers over the spring as they fell off and they are what hold the clips.
      Lyle
      • Mathew S.
        • July 9, 2015
        • 137
        There are remnants of plastic clips on my wiper arm, but not sure how they go on or intended to hold.
        • Jimmy P.
          • June 24, 2014
          • 1695
          Here are some pictures of the wiper arms showing the clip locations from my 73. They are the same on your 70. The diagram is from Paragon's parts catalog also showing the clip locations. Four clips on the passenger side and three clips on the driver side. BTW, if you are a little hesitant about using the propane torch to re- solder as Russ suggests try using a daub of Locktite Superglue Gel in that same area to hold the tube in place. That's what I use when I break mine loose every time I accidentally catch it on a towel when cleaning/ washing the car
          Hope these help.
          Jimmy
          1973 Convertible
          L48,M20,N40
          Mille Miglia Red/Oxblood
          • Tom L.
            • October 17, 2006
            • 1439
            I used one of these to solder mine on. Worked perfect.
