1962 Clock - NCRS Discussion Boards
1962 Clock
  • Terry D.
    • May 31, 1987
    • 2692
    1962 Clock
    So I get the clock repaired and try to put it back in. I get it past the notches and start to turn it clockwise and it goes in and past the notch and starts to turn but only goes about 3/4 of the way. Have had it in and out several times always ends up at twelve 0 two instead of straight up 12. What is this old sometimes forgetful mind missing?
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 1962 Clock
    Terry,
    Possibly the convoluted spring is in wrong?
    I can't imagine anything else.
    Bruce
    • Terry D.
      • May 31, 1987
      • 2692
      Re: 1962 Clock
      I'll try that but I don't see that there is a right side up on that type of spring! Just find it hard to believe I am the only one to have this trouble. Then again maybe not so hard to believe with the luck I have been having, lol!
      • Frank D.
        • December 27, 2007
        • 2703
        Re: 1962 Clock
        They can be a royal PITA - I had to force this one out of a 61 dash....you can see the spring and how it's situated in the photo..
        Maybe a bit of silicone grease -- like is used on "O" rings would help...around the spring and other contact points..
