C2 door hinge bushings and pins - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1582
    Are the pins and bushings sold by LIC a good fit. The ones I got from the local auto parts store are the wrong sizes.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: C2 door hinge bushings and pins
    They were available from GM and probably still are. I got a set from a Cadillac dealer some years ago. They used the same size bushings and pins for many years across all GM lines. The new pins I received were about 1/4" longer than the original so I ground them down to the original size the bushings fit fine.
    • Bill M.
      • 1322
      I used a set in my 66 a couple of years ago from LIMCT and they were fine
      • Keith B.
        • 1582
        Bill who is. LIMCT?
        • Bill M.
          • 1322
          Whoops meant L I Corvettes
            • 43219
            Keith------
            Pin and bushings are available from GM under replacement part numbers:
            pins------GM #20046147
            bushings-----GM #9721917
            The pins need to be shortened which is easy.
            • Keith B.
              • 1582
              thanks Joe called my local dealer and got them ordered well cheaper then the vendors
