The Answer to Every Electrical Problem!!!! - NCRS Discussion Boards
  • Joe R.
    • July 31, 1976
    • 4552
    The ground! Duh!
    JR
  • Roy S.
    Past National Judging Chairman
    • July 31, 1979
    • 1027
    Re: The Answer to Every Electrical Problem!!!!
    With our beloved Corvettes, that statement is true probably 95% of the time.
    • Richard G.
      • July 31, 1984
      • 1718
      The amp gauge on a mid year will work without a ground.
      I can't think of anything else.
      • Michael J.
        • January 27, 2009
        • 7167
        My gas gauge has two grounds, the brown wire and the black/white wire.....and it doesn't work.
        • Roy S.
          • July 31, 1979
          • 1027
          Really, two grounds? My guess would be your problem is probably one or both of those grounds are bad!!! Don't ask me how I know.
          • Michael J.
            • January 27, 2009
            • 7167
            Right Roy, and when a restorer doesn't know how to wire a tanker's unique sending unit, this is what you get. But, I am experienced at rewiring these mistakes, and will soon have it working, I hope.........
            • Donald O.
              • May 31, 1990
              • 1593
              Originally posted by Joe Ray (1011)
              The ground! Duh!
              JR
              Unless you've let the smoke out of the wires.
              • Mel S.
                • August 31, 1992
                • 264
                I had a problem with my fan switch for my 66 w/air. After two months of trouble shooting, it was a ground that i forgot to reconnect.
                • Michael J.
                  • January 27, 2009
                  • 7167
                  I finally figured out why my gas gauge was deflecting along with the battery gauge (and not working) with the brake lights on and turn signals blinking. The so-called "restorer" connected the ground wire from the sending unit to the common ground from the tail lights, instead of separately ground it. You wonder what people are thinking (or not thinking) when they restore a car......
                  • Dick W.
                    • 10483
                    The ground! Duh!
                    JR
                    Dick Whittington
                    • Steven B.
                      • June 30, 1982
                      • 4013
                      I had to get some of that for 3 cars-after I got replacement wires. It works just like the original smoke. Good stuff and highly recommended!
                      • Roy S.
                        • July 31, 1979
                        • 1027
                        Actually quite footing that this is a Lucas product, don't ask me how I know!!!!
                        • Paul O.
                          • August 31, 1990
                          • 1716
                          That smoke does not work in USA wiring as it flows backwards negative to positive.
                          • Edward B.
                            • January 1, 1988
                            • 537
                            The Lucas smoke works fine on both sides of the Atlantic as it facilitates the electron flow from negative to positive. Problems arise when the smoke leaks out and the electrons get stuck. Lack of ground or earth is the answer to every electrical difficulty and is usually fixed with a BFH.
                            • Steven B.
                              • June 30, 1982
                              • 4013
                              And the reason Brits drink warm beer---
